Jul 16th, 2024, 5:43am
cannot be found in the switched master of the instance (Read 9449 times)
supermoment
Mar 08th, 2010, 11:18pm
I tried to run postlayout sim in cadence with calibre view.
I got DRC, LVS clean. I am able to generate PEX netlist
when in the calibreview pop up, I choose proper cellview map. example below:
(nmos
 (foundry nmos spectre)
   (b B)
   (d D)
   (g G)
   (s S)
I got 32 warning and 0 error.
WARNING: Could not find property ID for "l".
WARNING: Could not find property ID for "w".
WARNING: Could not find property ID for "ad".
WARNING: Could not find property ID for "as".
WARNING: Could not find property ID for "pd".
WARNING: Could not find property ID for "ps".
WARNING: Could not find property ID for "m".
repeat....
When I try to run postlayout by using config method, which choosing calibreview. I failed to generate netlist and the error as below:
ERROR: Netlister : terminal 'in' of instance 'I0', in cell 'inverter4_tb', view 'schematic' : cannot be found in the switched master of the instance.
ERROR: Netlister : terminal 'out' of instance 'I0', in cell 'inverter4_tb', view 'schematic' : cannot be found in the switched master of the instance.
The cell is just a simple inverter. I am able to run in prelayout but fail to run in postlayout..
Could anyone help me
thanks in advance
aaron_do
Re: cannot be found in the switched master of the instance
Reply #1 - Mar 9th, 2010, 4:39am
I find that if you don't use all caps for the terminal names, you get this error. So you should rename your terminals IN and OUT both for schematic and layout. I'm not sure if there's another solution. Also, it seems that a .stl file is generated in the /template folder when you run LVS. I find that I need to delete the .stl file (you could back it up if you want) and re-run LVS after changing the names of the terminals or adding new ones.
Those are the solutions I use but there may be a more correct way of solving the problem.
Not sure about the warnings...
cheers,
Aaron
supermoment
Reply #2 - Mar 9th, 2010, 9:54pm
got it. thx
