Sep 26th, 2024, 2:58pm
fully differential OPAMP : common mode stability (Read 6535 times)
Dipankar
Mar 09th, 2010, 4:35pm
Dear All,
             I was simulating common mode stability of an OPAMP inserting probe (vdc=0) at the common-mode feedback branch by "stb" aalysis.PM. To get a a good PM  ( ~50-60 deg) I need to reduce the gain of my CMFB amplifier to such an extent that dc voltage of vout+ and vout- is off from the CM level by atleast 60-70 mV. OPAMP is folded cascode (pmos input diff pair) and CMFB is DDA-CMFB. Can someone help ?
With Thanks and Regards,
Dipankar.
Manas
Bangalore,INDIA
Re: fully differential OPAMP : common mode stability
Reply #1 - Mar 9th, 2010, 10:58pm
What u mean by DDA-CMFB ??
View Profile Manas   IP Logged
Berti
Reply #2 - Mar 9th, 2010, 11:28pm
I have once implemented source degeneration to lower the gm of the DDA-CMFB (Manas: DDA=differential difference amplifier) and compensated the lower gain by a higher output resistance. In this way the bandwidth of the CMFB is reduced (unfortunately) and consequently the PM increased.
But maybe you can find a way to shift you first pole to lower frequencies?
Cheers
subgold
Reply #3 - Mar 10th, 2010, 5:26am
hi,
i dont know your output range and desired cm level, but given an folded cascode output, 70mV of cm offset basically indicates your dda is just inactive, i am afraid you will suffer a serious CMRR degradation.
i think berti's suggestion might be helpful as long as you still have some freedom to manipulate the gain and speed of the main amp. you could also try to optimize the sizing of your cascode transistor and find a better way of feeding back your cmfb loop.
otherwise i see no choice but burning more current into your dda.
Dipankar
Reply #4 - Mar 12th, 2010, 6:10pm
Thanks for the inputs. I'd like to discuss one issue  on the same line.
I use the following test bench (attached as TB_OPAMP.jpeg) to characterize all ac parameters.  Under certain bias conditions the
loop-phase plot starts from 0 - rises to  +90 and then falls where as the loopgain plot rolls of normally from some 90 dB(see "cmfb_stb_plot.jpeg").  It occurs only at certain bias conditins. But at the same condition open loop gain or phase ( ( VF("/OUTP) - VF("/OUTN") )/ (VF("/inp") - VF("/inn")) ) looks normal.  If I do the same stb simulation with the feedback resistors removed I get reasonable stb-phase-plot (starting from 180 and rolling ogg accordig to pole positions) . So  I'm curious which signal loop is considered by spectre  while doing "stb". I  guess I Should remove the feedback resistors while doing cmfb loop analysis by stb.  Please advise.
Dipankar.
subgold
Reply #5 - Mar 15th, 2010, 8:19am
Dipankar wrote on Mar 12th, 2010, 6:10pm:
i think the position of your stb probe is wrong. it should include both CMFB loop and the resistive feedback loop. now the probe excludes the resistive feedback. basically the probe should be directly connected to either the input or the output of the main amp.
