Jul 16th, 2024, 6:35am
Error: genvars are not yet supported (Read 5302 times)
pkd
India
Mar 15th, 2010, 2:01pm
Dear all,
I am facing this error while compiling the code below for an ADC which is an exact copy of VerilogA manual downloaded from this forum only.
Here is the error:
Quote:
Error found by spectre during SpectreHDL compile.
"/home/pratap/cadence/designs/verilogA_try/adc/veriloga/veriloga.va", line  14: "genvar <<--? i;"
"/home/pratap/cadence/designs/verilogA_try/adc/veriloga/veriloga.va", line  14: Error: genvars are not yet supported
Here is the source code in verilog-A...
// VerilogA for verologA, adc, veriloga
`include "constants.vams"
`include "disciplines.vams"
module adc(in, clk, out);
	parameter bits = 8, fullscale = 1.0, dly = 0, ttime = 10n;
	input in, clk;
	output [0:bits-1] out;
	electrical in, clk;
	electrical [0:bits-1] out;
	real sample, thresh;
	integer result[0:bits-1];
	genvar i;
	analog begin
		@(cross(V(clk)-2.5, +1)) begin
			sample = V(in);
			thresh = fullscale/2.0;
			for (i = bits - 1; i >= 0; i = i - 1) begin
				if (sample > thresh) begin
					result[i] = 1.0;
					sample = sample - thresh;
				else begin
					result[i] = 0.0;
				sample = 2.0*sample;
		for (i = 0; i < bits; i = i + 1) begin
			V(out[i]) <+ transition(result[i], dly, ttime);
Please let me know if I am doing something wrong or if I am missing some thing.
-pkd
Re: Error: genvars are not yet supported
Reply #1 - Mar 15th, 2010, 9:58pm
Try the Spectre compliant versions.
pkd
India
Reply #2 - Mar 15th, 2010, 10:48pm
I am using mmsim70 for spectre.
As far as I know that is one of the most recent versions of spectre.
In that also I get the same error.
-pkd
Reply #3 - Mar 16th, 2010, 6:12am
You missed what Ken was saying.  Click Verilog-AMS in the header, in the functional blocks section there is:
Data converter (LRM compliant, Spectre compliant, test, dg-vams3-26, dg-vams3-27)
You want this link:
http://www.designers-guide.org/VerilogAMS/functional-blocks/data-converter/conve...
