May 20th, 2024, 8:22pm
Please help, mismatch of mos transistor (Read 2523 times)
guanze
Apr 15th, 2010, 7:01am
I am one beginner of monte carlo simulation. I need help urgently.
Now I want to simulate the drain current mismatch of mos transistor with respect to vgs-vth, where vgs-vth is defined as design variable and drain current defined as output in ADE and monte carlo.
Could somebody tell me, how can I simulate the mismatch of drain current with respect to vgs-vth and show the result by means of swept vgs-vth, instead of iteration number?
Thank a lot
Re: Please help, mismatch of mos transistor
Reply #1 - Apr 19th, 2010, 8:36pm
Hi guanze,
I don't know what you know and what you don't know. It seems that you have a SPICE model supporting monte-carlo simulatin. It seems that you have already known ADE interface and started monte-carlo in ADE. Could you please put forward a question with specific problem?
Yawei
