aaron_do
Hi RFICDude,
the expression,
(2U-1)+2*sqrt(U*(U-1))
does not appear to be the same as Gumax. In the paper you referenced, the author says, "in the special case where the fourport embedding network consists of two decoupled ports", i.e. just an input and an output matching network. The value Gumax which I was talking about involves setting S12=0...
Also, I tried to trace back the derivation of the above formula and I reached a road block. In the paper you referenced, the author references the following:
A. Singhakowinta, A. R. Boothroyd, "On linear twoport amplifiers", IEEE Trans. Circuit Theory, vol. CT-11, no.1, p.169, Mar 1964.
In the above paper, the formula is stated without proof, and is referenced to a future publication by the same authors. Well I looked for a future publication by the same authors and found only 1 published two years later:
"On Analysis and Representation of Two-Port", IEEE Trans. Circuit Theory, vol. 13, no. 1, 1966, pp. 102-103.
And the paper above simply referenced their original publication in 1964. i.e. the two papers cite each other, and neither of which actually derive the equation. Sounds like instability due to positive feedback to me.
Do you have any idea where I can find a derivation of the formula?
thanks, Aaron
BTW, Gumax from spectre is dependent on Z0 while (2U-1)+2*sqrt(U*(U-1)) is not. BTW according to my simulations, Gumax is a very close approximation of U.
