Jan 20th, 2026, 4:00am
troubles with wait instruction (VHDL) (Read 4020 times)
happy_designer
Apr 21st, 2010, 10:17am
I'm trying to write the code of a pwm generator in VHDL. The entity "pwm_generator" takes :
duty value as input,
frequency and number of step (for one period) as generic parameters
It should return a pwm signal depending on the duty value.
My problem comes since I'm trying to make it as generic as possible. Then I try to calculate a clock period with the generic parameters (frequency, nb_of_steps and duty) and I want to use this result as a parameter of a wait instruction. In this case, the simulator is blocked in infinite loop as he waits 0.0 sec in my loop.
Is there a simple solution for this problem ? (can we force the calculation of v_delay ??)
P.C
entity pwm_generator is
     generic (
           cst_nb_step : natural := 255 ;
           frequency : natural := 40000
   port(
           duty_value : in natural ;
           pwm : out std_logic
end entity pwm_generator ;
architecture beh of pwm_generator is
signal s_clock : std_logic := '0' ;
signal s_pwm : std_logic := '0' ;
signal s_delay : real := 0.0 ;
begin
process
variable v_delay : time := 500 us ;
     begin
           v_delay := (1/frequency/cst_nb_step * 1 sec ) ;
                 s_clock <= not(s_clock) ;
                 wait for v_delay ; -- works correctly with 500 us value
end process ;
process(s_clock)
variable counter, ratio :  natural := 0 ;
     begin
           ratio := ( duty_value * cst_nb_step / 100 ) ;
     if (counter /= 255) then
           if (counter >= ratio) then
                 s_pwm <= '0' ;
           elsif (counter < ratio) then
                 s_pwm <= '1' ;
           end if ;
           counter := ( counter + 1) ;
     elsif (counter = 255) then
           counter := 0;
           s_pwm <= '1' ;
     end if;
end process ;
pwm <= s_pwm ;
end architecture beh ;
jerome_ams
Re: troubles with wait instruction (VHDL)
Reply #1 - Oct 26th, 2010, 8:30am
As you do not dynamically change the v_delay value (it is calculated from generics), I would suggest to take its description out of the process and to declare it as a constant:
constant v_delay : time := 1/frequency/cst_nb_step ;
This way v_delay will be calculated.
Hope it helps,
Jerome
