Aug 15th, 2024, 2:49am
Common Source LNA stability (Read 7946 times)
unevb
Apr 26th, 2010, 9:58pm
I am designing a single ended common source cascode LNA with inductor degeneration  for a 5.5GHz receiver
Is there any intuitive explanation about how the k-factor is dependent on the circuit paramaters (gm, vds or L,C values). When I burn a current 'I' in the LNA, k>1 across 10MHz to 10GHz, it is unconditionally stable. But if I reduce the current to 'I/10' , all other circuit performance are meeting spec, but the k drops below 1 for most the the frequency of interest.
What is the relation between circuit parameters and k-factor or stability? If k is poor what can i improve in the circuit?
Re: Common Source LNA stability
Reply #1 - Apr 29th, 2010, 8:54am
unevb wrote on Apr 26th, 2010, 9:58pm:
- Put shunt resistors for input or output or both which are ideally effective only for frequency range of poor K.
- Resize transistor
- Neutralization
http://www.designers-guide.org/Forum/YaBB.pl?num=1264582305/5#5
unevb
Reply #2 - May 5th, 2010, 10:46am
Why is k-factor an issue at RF but not an issue at low frequency (audio-range) circuits? For a single device k<1 at low frequency (where we compute MSG) and after the threshold frequency k>1 and we care about MAG, so I would think k-factor to be important at all frequencies.
If we are using a device which has k>1 at a mm-wave frequency eg. 60GHz  then it is said to be "unconditionally stable" when used at 60GHz. Does this account for possible oscillations at lower frequencies when k becomes less than 1?
Not many IEEE Papers on LNA circuits talk about the k-factor of the circuit. I have connected a 90nm device I am using , in common source configuration and plotted k-factor for different dimensions and it is never unconditionally stable over entire frequency range. Is there something that can be done at the architecture level to take care of this? I have not seen integrated circuits using input shunt resistors because of noise considerations.
Thanks!
Reply #3 - May 5th, 2010, 11:00am
unevb wrote on May 5th, 2010, 10:46am:
K-factor is not used except for LNA generally.
K-factor is not used for PA design where large signal is concerned.
I don't use K-factor even for LNA.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1218635777/5#5
http://www.designers-guide.org/Forum/YaBB.pl?num=1266403928/4#4
Consider loads for RF and audio.
Former is a resonator in many cases where impedance change drastically with frequency.
Latter is a resistor in many cases where impedance almost does not change with frequency.
pancho_hideboo wrote on Apr 29th, 2010, 8:54am:
- Resize transistor
- Neutralization
It seems you only know "EDA Tool Play" and technical paper.
We make bias circuitry and feed back network having frequency characteristics to prevent unpreferable oscillation in actual circuits.
Shunt resistor which is effective for some frequency range is also this purpose.
Cascode structure could be candidate for some case.
BTW, have you been able to understand the following ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1272508752/3#3
MAG, MSG and U are not dependent on reference impedance even if S-parameter expressions are used.
« Last Edit: May 6th, 2010, 2:06am by pancho_hideboo »
unevb
Reply #4 - May 5th, 2010, 6:33pm
Thanks for the reply. It is true, I am still at the very early stage in RF design and right now beginning to pick up "EDA-tool" play and learn from Technical papers. Thanks for your patience in answering my questions.
RFICDUDE
Reply #5 - May 7th, 2010, 7:32pm
By "unpreferable oscillation" we mean that the real part of the impedance is "negative" over some frequency range which can only happen if there is positive feedback.
You are wise to be concerned about low frequency stability when working with microwave and millimeter wave circuits. Often times the low frequency gain is so high (as compared to the desired high frequency gain) as to cause positive feedback at low frequencies. This can result in sinusoidal oscillations at HF, VHF or UHF frequencies, or (even worse) wideband chaotic instability.
As Pancho suggested, low frequency terminations to prevent positive feedback at low frequencies is effective (a few books cover this). It can be more problematic in RC circuits. Bandpass tuned circuits may be less of a problem because the low frequency gain is naturally reduced by the reduced load impedance at low frequencies.
