samiran
Hi Marq,
Thanks for the suggestion. My situation is to develop a model of opamp which includes the small-signal and large-signal (specifically slewing for large-step input/high frequency sinusoidal signal) behavior in one model. And also there will be an output buffer stage (mainly to take care of output resistance). But, I am stuck in implementing this as I am not really successfully putting the condition when to start slewing at the output instead of following the small-signal behavior.
In my model, I have a gain stage modeled as VCCS (multiplication factor = gm, controlling voltage = input voltage), ro and a cap (CL) in parallel. This ro and CL are setting the dominant pole. And in the output stage its simply a VCVS (multiplication factor = 1, controlling voltage = voltage across the CL) with a series o/p resistance, Rout.
What I am trying to do to implement slewing, is when input differential voltage is exceeding a certain voltage level, just setting a maximum constant current (Imax) through CL. But it is not really helping as I am unable to see any slewing for rail-to-rail input step.
Do you have any idea, how this can be implemented?
Thanks for you patience, with regards Samiran
