May 15th, 2024, 7:20am
Q factor of nmos varactor (Read 7020 times)
supermoment
May 24th, 2010, 5:05am
I try to simulate the Q factor of a nmos varactor by using S parameter.
Q=imag(Y11)/real(Y11)
one port setup.
I varied the width & length and check the Q.
I found that Q is much higher when length  is large for a given area.
It is completely contradictory to the theory that nwell resistor is the main source of resistance, should keep length to min.
I suspect the foundry does not model the varactor properly.
Now the behavior looks like a nmos gate leakage instead.
rfcooltools.com
Re: Q factor of nmos varactor
Reply #1 - May 25th, 2010, 11:48am
What process node are you using?
Does the Q vs length consistent over length?
Is the Q vs length consistent over bias?
Describe what is connected to the 3or 4 nodes of the varactor?
J
love_analog
Reply #2 - May 31st, 2010, 7:37am
can you just look at the real resistance of the varactor. What sort of model is the foundry providing you - just S parameter model?
loveanalog.blogspot.com
The Power of Analog
love_analog
Reply #3 - May 31st, 2010, 7:38am
BTW, typically foundry will only provide fixed templates of varactor so you cannot vary the length and expect to get correct results. Maybe only discrete lengths
The Power of Analog
supermoment
Reply #4 - Jun 2nd, 2010, 9:54pm
As in previous post, Q becomes better if the length is larger.
The contradictory statement: In many journals, the length should be set to around the min length so that the Q is not degraded.
I simulated the Q with sp analysis. Foundry does not provide Q for nmosvar
Foundry does not provide discrete length.
Mayank
Reply #5 - Jul 7th, 2010, 3:55am
Can you also try Q measurement without sp analysis ?
Simply using an AC analysis.
Q=imag(Z)/real(Z)
where Z = Vac/Iac.
--M
supermoment
Reply #6 - Jul 7th, 2010, 4:50am
It looks correct if using AC analysis.
The Q is quite reasonable.
thank you very much!
just wonder why sp fail to give me the correct result..
I seldom use sp analysis since i am new to RF
[img][/img]
supermoment
Reply #7 - Jul 7th, 2010, 4:52am
But it does not relate to what happened in the  weird vco tuning range.  :D
vp1953
Reply #8 - Jul 7th, 2010, 8:59am
Hi Casual,
Many foundries have an nmosvar and nmosvar_rf - the rf version is characterized for high frequencies whereas the non-rf version works only for low frequencies; and so if you run a rf simulation on the low frequency version, results may not be very meaningful.
