Apr 28th, 2024, 12:19pm
Need Verilog A model for Fully differential OTA (Read 8464 times)
siegi
May 25th, 2010, 3:25am
Could someone please share FD OTA verilog A source code !!
Thanks in advance
Re: Need Verilog A model for Fully differential OTA
Reply #1 - May 25th, 2010, 6:09am
What if you take this model:
http://www.designers-guide.org/VerilogAMS/basic-models/ideal-opamp/ideal-opamp.v...
and change it from a V to an I output?
I(out): V(in) == 0;
siegi
Reply #2 - May 26th, 2010, 4:03am
Thank you...but i'm looking for OTA with gain,bandwidth,slew rate, CMRR, PSRR, Power Supply.
Reply #3 - May 26th, 2010, 4:43am
There's another guy on this forum who has a list of points for newbies, including one about how not to expect us to do all your work for you.  Have you even tried to write your model?
carlgrace
Berkeley, CA
Reply #4 - Jun 25th, 2010, 4:32pm
There is a fully-differential opamp model in the bmslib, but I have had some convergence issues using it.
I think Geoffrey's suggestion was great.  Take an opamp model that has what you want, figure out how it works, and then modify it to be fully differential. Don't be afraid of it, it isn't all that hard.  You just have to add an extra output, invert it with respect to the original output and make sure they are both referred to the same common-mode voltage.  Good luck!
eelxpeng
Reply #5 - Mar 6th, 2014, 6:21am
I did one with gm, Gain, Output DC Voltage but without slew rate or voltage limit.
'include "constants.vams"
'include "disciplines.vams"
module diff_OTA(vip,vin,vop,von,vss)
     output vop,von;
     input      vip,vin,vss;
     electrical vip,vin,vop,von,vss;
     parameter real vcm=1.65, Av=1800, gm=1.8m;
     real Gout,vodif;
     analog begin
           @(initial_step) begin
                 Gout=gm/Av;
           vodif=Av*V(vip,vin);
           I(vop,vss) <+ (V(vop,vss)-(vcm+vodif/2))*Gout;
           I(von,vss) <+ (V(von,vss)-(vcm-vodif/2))*Gout;
