Jul 17th, 2024, 3:36pm
Demodulator (Read 1611 times)
Mahesh
ahmedabad
Demodulator
Jun 01st, 2010, 5:24am
What is the difference between simple demodulator and Multi carrier demodulator?
Cato
Re: Demodulator
Reply #1 - Jun 8th, 2010, 6:09pm
a multi-carrier demodulator is what it says, a demodulator for multiple carriers.  basically, when you do multi-carrier modulation, you modulate multiple carriers with your message signal.  modulating multiple carriers give you better interference immunity, higher data rate, or some combination of the 2.  you can check Wikipedia.
sorry if that is a bit vague.
