Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 5:17am
Home
Help
Search
Login
Register
PM to admin
Simulators
AMS Simulators
› Inherited supply connections do not work in AMS?
Previous topic
Next topic
Inherited supply connections do not work in AMS? (Read 3219 times)
HdrChopper
Jun 05
th
, 2010, 2:20pm
After running a long simulation where a digital sub-block using inheritance supply connectors for the internal global supply nets VPOS! and VNEG! I realized the supply voltages did not got actually connected to that block.
I had to tweak my bench and by hardwiring both VPOS! and VNEG! to the actual supply lines pins coming into the block one hierarchy level up.
Is this a known bug or did I do something wrong?
Any feedback is appreciated.
Tosei
Keep it simple
IP Logged
Re: Inherited supply connections do not work in AMS?
Reply #1 -
Jun 6
th
, 2010, 8:44pm
Hi Tosei,
I did use inheritance connection when I simulated using ams simulator. It worked fine. Did you set up the connection rule correctly?
What's connection rule do you use? Please select an inherited connection rule.
Yawei
IP Logged
Reply #2 -
Aug 25
th
, 2010, 10:36pm
Hi Tosei,
Have you resolve that problem? I encounter similar problem. My software version is IC.6.1.4.500.6.
Yawei
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
»» AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
