Jul 18th, 2024, 3:33am
Error running Cadence ams(spectre) using actual spectre netlist (Read 3939 times)
richloo
Oct 07th, 2010, 6:35pm
1)by using "OSS-based netlister with irun"
ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
           Caching library 'worklib' ....... Done
psvt25 #(1)   I22 ( .b(VP), .g(A), .d(ZN), .s(VP));
ncelab: *E,SPPBYO (./netlist.vams,17|9): Parameter assignment by order is not supported for analog primitives.
Question:
Is it due to transistor model?
2)by using "Cellview-based netlister with ncvlog,ncelab,ncsim"
Work perfectly.
Re: Error running Cadence ams(spectre) using actual spectre netlist
Reply #1 - Oct 8th, 2010, 6:38am
richloo wrote on Oct 7th, 2010, 6:35pm:
Do you know what this is supposed to be doing?  It looks to me that you're instantiating a pmos (standard-vt, 2.5v, from a model library) with a parameter of 1.  Is that length or width, or something else entirely?
I would expect it to look more like #(.l(.25u), .w(2u))
