Jul 18th, 2024, 10:01pm
Save and plot node voltage in post-layout simulation (Read 3790 times)
Jun 06th, 2010, 8:53pm
Hi Guys,
I failed to save and plot node voltage in a post-layout simulation. Last week I ran a post-layout simulation with RC extracted view. That was extracted using Assura. I tried to save and plot a few nodes inside the RC extracted view. I set up the config view, chose the schematic view first. Then select a few nodes in the schematic. Then I switched to RC extracted view in Hierarchy editor and Run simulation.  But two nodes in all my selections are not saved. The following is detailed information in ncsim.log.
Quote:
ncsim> probe -create -emptyok -database ams_database {adc_sim.I0.u_adc.muxout_m}
Created probe 4
ncsim> probe -create -emptyok -database ams_database {adc_sim.I0.u_adc.muxout_p}
Created probe 5
Transient Analysis `tran': time = (0 s -> 50 us)
Warning from spectre during IC analysis, during transient analysis `tran'.
   adc_sim.I0.u_adc.muxout_m is not present in the design.
   adc_sim.I0.u_adc.muxout_p is not present in the design.
Trying `homotopy = gmin' for initial conditions.
Trying `homotopy = source' for initial conditions.
Any comments are appreciated.
Yawei
boe
Re: Save and plot node voltage in post-layout simulation
Reply #1 - Jun 25th, 2010, 7:47am
ywguo,
The message suggests that the name does not exist.
A few ideas: Did you check your extracted view/netlist that it contains the name? Is the hierarchy the same, did any flattening occur?
BOE
HdrChopper
Reply #2 - Jul 15th, 2010, 7:06pm
I faced similar issues like the ones Yawei had. However I was able to plot any node simulated from the extracted view by selecting the corresponding net from the schematic view.
That worked for me so far.
Best
Tosei
Keep it simple
