Jul 20th, 2024, 1:27am
Is the bandgap vref still insensitive to process and power supply voltage? (Read 2688 times)
newic
Jun 08th, 2010, 11:45pm
Bandgap reference design is to combine Vbe and K*Vt to generate a voltage reference that is insensitive to temperature.
Vref=Vbe+K*Vt
The resistor has +/-20% variations and power supply 10%
despap
Re: Is the bandgap vref still insensitive to process and power supply voltage?
Reply #1 - Jun 24th, 2010, 11:44pm
No, its not.
It is always required to correct the drift in Temp-Co due to process variation, so as to get temperature independent(to first order) Vref.
It can be a trim circuit.
N S
RobG
Bozeman, MT
Reply #2 - Jun 25th, 2010, 8:54am
Just to expand a bit. The bandgap output voltage is (ideally)
VOUT = UT*ln(IBE/IS) + K*UT
where UT is our friend kT/q and K is a gain ~8
K is determined by ratios so it is process independent.
UT is determined by your favorite God, and he/she doesn't appear to have plans for changing it, so count that as process independent.
IBE is the current in the relevant PN junction -- it is process dependent. Generally it is limited by the sheet resistance of your process: +/-30% or so, plus the temp co of the resistors. The temp co can increase or decrease the curvature of the temp response.
IS is the saturation current (reverse bias leakage) and is +/- 30% or so over process if you have a lazy fab. (IMO it is very well controlled, much better than +/-30%, like the Nwell resistor).
So your process dependent part of the equation is UT*ln(IBE/IS) and the variables are tempered by the ln function.
There are other non-ideal effects, like base current drop across the base resistance. These can be strongly process dependent and need to be designed around.
Power supply rejection is just a matter of shielding the pn junction and its current from power supply variations.
