Jul 19th, 2024, 11:28pm
differential delay cell with wide tuning range (Read 4398 times)
supermoment
Jun 27th, 2010, 8:40pm
I am looking for differential delay cell with wide tuning range. The delay range is from 30/40~60/70ps. Target is 50ps!
I tried to use simple differential cell with pmos active load + replica bias (Maneatis type without diode-connected transistor). I found the range is too small to cater process variation..
thinking for programmable load or mux...
any advice..?
any good high-speed delay cells?
Mayank
Re: differential delay cell with wide tuning range
Reply #1 - Jun 27th, 2010, 9:01pm
I feel Maneatis Delay Cell can be tuned over your required range by varying Tail Current Source.
Is the change in swing not acceptable to you ? Otherwise you should have obtained a good tuning range.
You can go for calibrated capacitive loading on oscillator nodes too, if needed.
supermoment
Reply #2 - Jun 27th, 2010, 9:24pm
yes. the amplitude is getting smaller in some range.
I notice there are two types of famous differential delay cell.
1) Maneatis type -->adjusting Vctrl (amplitude), changing I
2) Maneatis type -->adjusting Vbias (current), changing V
which one is better?
The only difference i found is the tuning range. 2) tends to be smaller range but frequently used in DLL
raja.cedt
Reply #3 - Jun 27th, 2010, 9:52pm
hi casual,
   upto my knowledge Maneatis cell can cover pretty wide range, so if you need more than that better go for calibration what mayank has reported.
 by the way what do you mean by '2) Maneatis type -->adjusting Vbias (current), changing V  '
Rajasekhar.
supermoment
Reply #4 - Jun 27th, 2010, 10:16pm
Yes. Maneatis delay cell is the most wide range i have ever found.
However the wide range is mostly cover the low freq range.
50ps delay and the input freq is 10Ghz. The amplitude is getting small at high freq.
Some designs do not use opamp, directly adjust vbias (Vbn) of the current source & replica bias.  You could refer to those DLL papers.
raja.cedt
Reply #5 - Jun 27th, 2010, 11:27pm
hi casual,
             how low you are getting..even i did one DLL for 3.2g in 4 stages which is almost like 80p. There i got roughly 350mv swing, even if you are not getting you can achieve good swing by changing little bit top pmos triode device.
could you please give me any reference
Rajasekhar.
supermoment
Reply #6 - Jun 27th, 2010, 11:49pm
A Wide-Range Delay-Locked Loop With a Fixed Latency of One Clock Cycle
Basically it is similar to maneatis type but it is without opamp. It is suitable for DLL application since DLL reset from max freq to target freq.
I need to cover process variations and i am using old process 0.18um. Pushing to the limit of 10GHz.
I manage to get it but the power consumption is relatively high.
