Jul 4th, 2025, 3:43am
Is there any LDO with output voltage which is the same as reference? (Read 4421 times)
DP_Design
Seoul.Korea
Jun 09th, 2010, 1:52am
I am going to design LDO that supplys 1.2V stable output.
I should use 1.2V reference voltage (BGR output) , which is the same voltage level of LDO output.
Generally LDO output is divided by voltage divider consisted of resistors such as attached figure.
Then Can I design the LDO without output divider?
If R1->0, is it ok ?
The alternative will be reference voltage division but i can't.
View Profile DP_Design   IP Logged
AnalogDE
Re: Is there any LDO with output voltage which is the same as reference?
Reply #1 - Jun 9th, 2010, 11:23am
Remove R1 and R2, take Out node to '-' input of opamp, then you just have a regular unity-gain buffer.
DP_Design
Seoul.Korea
Reply #2 - Jun 9th, 2010, 6:02pm
If I Use Unity-gain buffer, then the Output Load transistor should be so big for current driving and then Op amp gain decreased. Is it Ok? LDO supplies over 100mA. AnalogDE wrote on Jun 9th, 2010, 11:23am:
Mayank
Reply #3 - Jun 9th, 2010, 9:31pm
If you take the OUT Node shown in Fig. back to Opamp I/p Terminal, then it is not a Unity Gain Config.
Unity Gain Config will only be formed when you take the Opamp Output( i.e. gate of pMOS ) directly to it's i/p which doesnt make any sense for LDO.
Taking OUT node back to opamp is Ok, & it's done sometimes.
Just take care of the Big Bypass Cap you put at OUT Node doesnt affect the I/p Terminal of the Opamp.
Mayank
DP_Design
Seoul.Korea
Reply #4 - Jun 10th, 2010, 12:54am
Mayank wrote on Jun 9th, 2010, 9:31pm:
Mayank
Thanks for your answer, Mayank.
Do You mean "Taking Out node back to opamp" is "R1=0" ?
And What will be the problem of opamp affected by cap?
I can't get it..
Mayank
Reply #5 - Jun 10th, 2010, 9:02pm
Yes, exactly.
I can't get it..
The OUT node is slow coz of a large cap.
Just draw a small signal, solve KCLs & find out if you are not getting sm unnecessary Poles/Zeros -- just to be on a safer side.
I dont think it should be a problem.
Mayank.
