adelezy
Hi, All
I simulated one sixth-order elliptical Low-Pass SC Filter. The example that I used is <Demystifying Switched-Capacitor Circuits> MingLiang Liu P101
In the circuit, ideal opamps and switches are used. OP's gain, UGBW and slew rate was considered and checked. The switches' on resistor is set to 1ohm. PAC simulation result is that 0db in pass band and w-3db is also right, but probelm exists in tran analysis. The amplitude of sine wave is much smaller than input, and the output attenuation is about -5db. The other problem is that output wave is like saw wave, not sine wave.
Thank you.
