Jul 16th, 2024, 10:35am
Pages: 1 2 3 4
Class B RF Power Amplifier ,IIP3/OIP3 Spectre (Read 10313 times)
purplewolf
Re: Class B RF Power Amplifier ,IIP3/OIP3 Spectre
Reply #15 - Jun 23rd, 2010, 12:07am
yeah.... i cant share..
can you do a favor(when u have really free time and relaxed Smiley) ,,, could u check iip3 oip3 in cadence for device biased in class B and tell me how u make the class B obey the text book equations of oip3= iip3+gain , iip3 = 9.6 + p1db as derived in razavi ..whether these equations are valid for class B since its output current is half sinusoid....
I am really stuck Sad
RFICDUDE
Reply #16 - Jun 23rd, 2010, 3:17am
1. A class B or even class AB amplifier may not follow the classic relationships between OIP3 and P1dB!
Why?
The power series expansion analysis that leads to the classic relationships between different order distortion components is usually performed on, what is assumed to be, a class A circuit. In a class A circuit, the nonlinear response of the circuit is not dependent on the input signal (it is only dependent on the nonlinear device and operating point).
For class B and deep AB circuits the quiescent current in the transistor(s) is dependent on the signal levels applied to the circuit, so effectively the power series coefficients may be changing as a function of the signal drive level. When this happens the assumption that the amplifier nonlinearity is characterized by single values for intermodulation intercept points is no longer true (i.e. OIP3 is not constant for all signal levels below compression).
So, for a true class B amplifier the OIP3 at small signal may be horribly smaller than you expect from a class A amplifier where OIP3 is constant.
So what do you do?
For a nonlinear power amplifier design you care about meeting a OIP3 or equivalently a IM3 or ACPR number at some specific average output power level (usually the highest required average power). So you could focus on meeting a IM3 number at that power level, but you want to be sure to still sweep two-tone input power to make sure you are not in a cancellation null where the IM3 is good and may become slightly worse as the the input power is reduced before declining again.
2. Simulation
I don't trust simulating linearity of class B designs with simulation techniques that assume moderate or weak nonlinearity (QPSS and PAC). I would first use two-tone transient, PSS or even harmonic balance (PSS HB) to understand what is going on large signal in the circuit then (once I trust the simulation is yielding the expected results) I can try the other analysis techniques and compare results before trusting the fast analysis techniques.
Again, for large signal operation (within 5-10dB of P1dB) be sure to sweep the two-tone power and look at the behavior of IM3.
I hope this helps a little.
Reply #17 - Jun 23rd, 2010, 4:15am
First of all, you have to understand difference between one large signal drive and two large signal drive correctly.
True P1dBin is defined for one large signal drive.
So P1dBin defined under two large signal drive has to be corrected.
True P1dBin will be 3~6dB larger than P1dBin defined under two large signal drive.
I usually use following relation.
P1dBin_One_Input=P1dBin_Two_Inputs+4.5dB
Some people set "Pin_dBm-3dB" for each tone's power in two large signal drive.
This is appropriate if you evaluate correct P1dBin from two large signal drive.
But this is never appropraite if you evaluate IM3 or IP3.
In evaluation of IM3 or IP3, you have to set "Pin_dBm" not "Pin_dBm-3dB".
For example, starter of the following thread are misunderstanding.
http://www.designers-guide.org/Forum/YaBB.pl?num=1262828862/26#26
The followings are summary of my simulation results of Class-B Amplifier.
(1) One Large Tone HB Analysis
P1dBin=24dBm
This P1dBin is true value.
If I roughly estimate P1dBin as Class-A operation from P1dB as Class-B Operation, it will be P1dBin=24-6=18dBm.
(2) Two Large Tone HB Analysis
P1dBin=19dBm
IIP3in=28.275dBm
Here this P1dBin is defined under two large signal drive, so this is not correct value.
So we have to correct this P1dBin value.
In this case, P1dBin_One_Input=P1dBin_Two_Inputs+4.5=19+4.5=23.5dBm.
This corrected value is well matched to result of (1).
(3) One Large Tone + One Small Signal HB Analysis
P1dBin=24dBm
IIP3=27.114dBm
The followings are conclusion for analysis of nonlinear amplifier such as Class-B and Class-C Amplifiers.
(1) IP3 can be defined for only linear system essentially.
You have to use IM3[dBc] for characterization for nonlinear amplifier such as Class-B and Class-C Amplifiers.
(2) IM3 output is not subjected to gradient of 3dB/dB line except for some region of input power level.
(3) IM3 characteristics of nonlinear amplifier such as Class-B and Class-C Amplifiers is affected by not only AM/AM but also AM/PM characteristics.
On the other hand, P1dBin is pure AM/AM characteristics.
Well-known relation of "IIP3=P1dBin+9.6dB" is derived under only AM/AM characteristics.
(4) Null of IM3 is true phenomena which is also observed in actual measurement.
This extremely small IM3 is a result of exquisite balance of AM/AM and AM/PM characteristics.
(5) You can not apply slave Small Signal Analysis subjected to master Large signal Analysis such as HBSS, PSS/PAC, QPSS/QPAC for nonlinear amplifier such as Class-B and Class-C Amplifiers.
Especially you must not apply them for evaluation of IM3.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1277203226/3#3
(6) If you use estimated P1dBin as Class-A operation and IIP3 where IM3 is relative subjected to gradient of 3dB/dB line,
IIP3=P1dBin+9.6dB can be satisfied.
In this case, P1dBin=18dBm and IIP3=28.275dBm.
P1dBin+9.6dB=27.6dBm is close to IIP3=28.275dBm.
« Last Edit: Jun 23rd, 2010, 7:13am by pancho_hideboo »
purplewolf
Reply #18 - Jun 23rd, 2010, 2:53pm
many thanks pancho_hideboo & RFICDUDE...let me absorb ur deep insight views......... Tongue
Reply #19 - Jun 28th, 2010, 7:32am
If I replace true FET with behavioral model FET of Class-B operation like following,
    Idrain=a1*Vgs+a3*Vgs3   for Vgs>=0.0
    Idrain=0.0                    for Vgs<0.0
IM3 of HB2 and HB1SS are coincident and are subjected to 3dB/dB line completely regardless of half sinusoid output current.
This model is :
 - No frequency characteristics
 - Simple AM/AM characteristics having only a1 and a3.
 - No AM/PM characteristcics
Well-known relation of "IIP3=P1dBin+9.6dB" is derived under this condition.
http://edocs.soco.agilent.com/display/ads2009/Amplifier2+%28RF+System+Amplifier%...
IM3 characteristics of nonlinear amplifier such as Class-B and Class-C Amplifiers is affected by not only AM/AM characteristics due to a1 and a3 but also AM/PM characteristics and AM/AM characteristics due to a2, a4, a5, a6, a7,.....etc.
Here "ai" is coefficient of order "i" in input/output relation.
The following is not appropriate.
pancho_hideboo wrote on Jun 23rd, 2010, 4:15am:
« Last Edit: Jun 28th, 2010, 12:44pm by pancho_hideboo »
purplewolf
Reply #20 - Jun 28th, 2010, 3:38pm
Am i right in making this claim "that IIP3 and OIP3 should never be considered/trusted for class  B and C amplifiers and only IM3 should be considered."
RFICDUDE
Reply #21 - Jun 28th, 2010, 5:08pm
Ah ha, it seems a little "EDA tool play" is instructive sometimes if, of course, one knows what one is doing!
Wink
Reply #22 - Jun 29th, 2010, 2:57am
Show me your plot results of Pfund_dBm and Pim3_dBm v.s Pin_dBm.
Are they subjected to 1dB/dB and 3dB/dB lines respectively ?
purplewolf wrote on Jun 28th, 2010, 3:38pm:
Generally yes.
Sometimes IP3 is not used even for Class-A Power Amplifier.
RFICDUDE wrote on Jun 28th, 2010, 5:08pm:
I don't think so.
"EDA Tool Play" is no more than "Tool Play" and never can exceed actual measurements.
pancho_hideboo wrote on Jun 28th, 2010, 7:32am:
This model is :
Actually such device never exists.
purplewolf
Reply #23 - Jun 29th, 2010, 4:36am
For my case ,in Spectre, if the amplifier is biased in class A and Class AB mode the classical relationship
1)OIP3 = IIP3+Gain
 2)IIP3=P1db+9.6
are fully obeyed .
I used
a)Two Tone PSS
b)Two Tone QPSS
c)PAC+PSS Sweep
and all of them give same results.
Another strange thing is I am getting is the same values of OIP3 and IIP3 for class A and class AB .
For Class A,VGS=1.2V ( 1 ,2 Obeyed)
P1dB(IN) = 18.6dBm, P1dB(OUT)=26.9dBm,Gain = 8.65
IIP3 =24.18dBm,OIP3=33dBm
For Class AB,VGS= 0.8V ( 1 ,2 Obeyed)
P1dB(IN) = 15.4dBm, P1dB(OUT)=23dBm,Gain = 7.5
IIP3 =24dBm,OIP3=33dBm
For Class  B ,VGS=0.55V( 2  Not  Obeyed, ??1 obeyed ??)
P1dB (IN) = 23dBm , P1dB(OUT)=27.65dBm,Gain = 6.6 dB
IIP3 =12.2dBm,OIP3=17.98dBm
Long story short:
The Spectre includes the IM null while extrapolating the Intercept lines . Since the BIG NULL in Class B makes the amplifier not obey the classical equations..Whereas for Class A , Class AB PA's ,LNA etc IM null is in-significant or near to the amplifier saturation and so the 3db slope is not effected and the classical equations obeyed.
I am attaching pics for Class A and Class B ..The IIP3 , OIP3 are independent of Input Power Level Sweep.
Reply #24 - Jun 29th, 2010, 4:47am
Your input power level is too small for evaluation of Class-B Amplifier.
I can't judge whether your simulation results are reasonable or not.
But I can say your simulation setup for QPSS is not appropriate.
purplewolf
Reply #25 - Jun 29th, 2010, 4:53am
I have used higher input power levels also..you can see in Class A(Plot 2)
and Class B (Plot 2)
purplewolf
Reply #26 - Jun 29th, 2010, 5:01am
i used the same setup for Class A and Class AB and the results are ok as indicated above.
purplewolf
Reply #27 - Jun 29th, 2010, 5:07am
Also the results are same for PAC & PSS ,Two tone PSS as well..
Only the non-linearity of Class B makes the difference
Reply #28 - Jun 29th, 2010, 5:17am
purplewolf wrote on Jun 29th, 2010, 4:53am:
No.
Your extrapolation point is too small.
If you use such small input power, power conversion efficiency of Class-B or Class-C amplifier is very small.
Consider how output level of -200dBm is too small.
Do you have an experience of actual measurement ?
Do you think it is possible to measure -200dBm.
And I can say your QPSS setup is not appropriate.
Quote:
sweepqpss  sweep  param=Pin  start=-60  stop=30  step=1  {
 qpss  qpss  flexbalance=yes  oversample=[1  1]  funds=["Tone1" "Tone2"]
+  maxharms=[9  3]  errpreset=conservative  tstab=10n annotate=status
Set maxharms=[9  9]  or maxharms=[15  15]
I set maxharms=[15  15] in HB2 analysis of Agilent ADSsim.
Can you plot results of 2tone-HB-QPSS as same style as mine ?
Don't use Direct Plot Form.
If I have device model of your MOSFET, I can resimulate and confirm your circuit by using more reliable simulator.
purplewolf
Reply #29 - Jun 29th, 2010, 6:40am
What extrapolation point should be used in Spectre then?? EP should be low so as to have 3 db slope at low power levels.
I dont have any experience in measurement .
The FET I am using is BPW_N_25_RF from UMC 90nm.
here'my qpss setup in pics..
what to use in place of Direct Form??
Pages: 1 2 3 4
