Yes. Maneatis delay cell is the most wide range i have ever found.
However the wide range is mostly cover the low freq range.
50ps delay and the input freq is 10Ghz. The amplitude is getting small at high freq.
Code:what do you mean by '2) Maneatis type -->adjusting Vbias (current), changing V '
Some designs do not use opamp, directly adjust vbias (Vbn) of the current source & replica bias. You could refer to those DLL papers.
