Jul 17th, 2024, 1:42pm
Jitter for serial link. (Read 3422 times)
raja.cedt
Jun 28th, 2010, 9:12pm
hi everyone,
i am not able to correlate the following jitter measurement result for an 6.25gb/s link .
up to my knowledge on jitter TJ=RJ+DJ..where RJ have to be expressed in pk-pk by multiplying with proper factor. Here in the plot also it matching almost. But my Question is
1.DJ is combination of all DDJ,PJ. But how come they are grater than DJ?
2. In the plot for every jitter type they are giving like p-p (means peak to peak), but what abut some delta-delta.
Rajasekhar.
Mayank
Re: Jitter for serial link.
Reply #1 - Jun 29th, 2010, 1:48am
What is DDJ ?
Pls. elaborate the Full forms of these antonyms.
Which kind of Jitter are you referring to as delta-delta ??
Could you how you are calculating delta-delta jitter. People use many terms for Jitter, which grows confusing.
I think PJ is period Jitter. What is PJ composed of - Device Noise ??
If yes, then What is RJ -- Due to Monte-Carlo variations OR Device Noise or Both ??
Also, what tool is this. Seen it for the first time.
love_analog
Reply #2 - Jul 29th, 2010, 7:29am
Raja
You got it wrong. DDJ is dual dirac jitter.
TJ = 2*Q*RJ + DDJ (not DJ)
loveanalog.blogspot.com
The Power of Analog
