Aug 16th, 2024, 2:50pm
How to setup parameters when do pss+pnoise for PFD+CP? (Read 4688 times)
easyads
May 26th, 2010, 10:59pm
Hi
   I am doing pss+pnoise analysis to simulate PFD+CP noise.
The PFD working frequency is 1MHz. The Ton(to eliminate dead zone) of CP 1ns.  And I have some problems and need you help.
1. how to choose pss harmonic in pss setup? 10,100 or 1000 for this case?
2. how to choose max sideband in pnoise setup? 10, 100 or 1000 for this case?
3. Can we choose max sideband in pnoise large than pss harmonic in pss? for example, maxsideband=1000, pss harmonic=10
Re: How to setup parameters when do pss+pnoise for PFD+CP?
Reply #1 - May 26th, 2010, 11:24pm
You chose the harmonics based on how many harmonics you want to see. Often it is set to one because you only need the fundamental. The number of sidebands determines the accuracy of the noise analysis. Start with a reasonable number and then increase it and see how the noise results change. Choose a value that gives you a reasonable trade off between accuracy and speed.
See http://www.designers-guide.org/Analysis/sc-filters.pdf for general information about setting maxsidebands.
harmonics and maxsidebands can be set completely independently of each other.
steff
Reply #2 - Jul 29th, 2010, 3:39am
I'm simulating a PFD/CP and I want to get the output noise. As written somewhere in the forum i drive the PFD with a vpulse and then i measure the output current noise.
While setting the simulation parameters in pnoise analysis ( i'm using cadence) i set "Sweeptype" to relative and then i choose the first armonic. Is this setting right? Or i have to set "Sweeptype" to absolute?
thank you.
