easyads
Hi I am doing pss+pnoise analysis to simulate PFD+CP noise. The PFD working frequency is 1MHz. The Ton(to eliminate dead zone) of CP 1ns. And I have some problems and need you help. 1. how to choose pss harmonic in pss setup? 10,100 or 1000 for this case? 2. how to choose max sideband in pnoise setup? 10, 100 or 1000 for this case? 3. Can we choose max sideband in pnoise large than pss harmonic in pss? for example, maxsideband=1000, pss harmonic=10 Thanks
