Jul 18th, 2024, 3:27am
booster amp in gain boosting ota design (Read 2731 times)
jszair
Jul 01st, 2010, 11:07am
Hi all
the attached is a booster amp used a gain boosted ota, from one berkeley student's project report.
I don't understand why he used cascoded tail current source with one transistor controlled by biasing network and another by cmfb. Any particular advantage of this topology compared to normal cmfb tail current source (two parallel transistor)?
Thanks!
Mayank
Re: booster amp in gain boosting ota design
Reply #1 - Jul 1st, 2010, 9:00pm
Just to make the TCS cascoded to improve Rout. Here, the current is controlled by the lower CMFB guided NMOS only, NOT the biasing ckt.
Just the advantage of Higher rout & closer to ideal current source. Other than that, it has a disadvantage of 100% cmfb control instead of only a part as is the case with parallel bias + cmfb control NMOSes.
love_analog
Reply #2 - Jul 29th, 2010, 7:06am
Perhaps he using this method to close the CMFB loop. Never seen anyone do it like this before. If you plan to use it, make sure you write the equations well and simulate it (esp startup conditions since you will could have a zero operating point, ie the output is zero and the ckt still converges).
loveanalog.blogspot.com
The Power of Analog
