Jul 16th, 2024, 4:07am
Assura QRC run error (Read 3411 times)
nickei1121
Berkeley
Jul 01st, 2010, 12:30pm
I ran into a problem when using Assura QRC.
When I run the QRC for the first time when I open cadence, it works successfully. However, I make some layout change, run LVS again, and then I want to run the QRC, it fails and shows this error message in the CIW:
*Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
I found some people have same problem using RCX. I tried follow their ways for QRC but still giving same errors. So if anyone has suggestion, please let me know, thank you so much.
nickei
