Then what's the role of MP3 & MN5?
It seems that the MP3 and MN5 construct a postive feedback, is there
a stability issue?
Then how the CMFB works?
What the GBW depends on when at a cap loading?
carlgrace wrote on Jul 9th, 2010, 1:46pm:The circuit is an amplifier. The circuit on the left is a simple OTA. Then the output current of the OTA is mirrored into the PMOS device MP2. The mirrored current is then dumped into two resistors to generate the output voltage. These resistors also generate a common-mode output voltage which is used for the common-mode feedback.
The gain is related to the gm of the input device, the two current mirror gains and the value of the output resistor.
Carl
