Jul 19th, 2024, 7:24am
how does this circuit works?  help! (Read 4510 times)
xwj623
Jul 05th, 2010, 12:01am
this circuit confused  me for a long time.
how does it works? And can someone tell me some reference papers or key words?
thanks.
xwj623
Re: how does this circuit works?  help!
Reply #1 - Jul 6th, 2010, 7:56pm
Is there nobody  know this circuit?   Sad
raja.cedt
Reply #2 - Jul 6th, 2010, 10:00pm
hi,
  in the circuit node names are not visible so don't know proper connectivity, so could you please post with neat schematic. By the way from where you got this ckt?
Rajasekhar.
carlgrace
Berkeley, CA
Reply #3 - Jul 9th, 2010, 1:46pm
The circuit is an amplifier.  The circuit on the left is a simple OTA.  Then the output current of the OTA is mirrored into the PMOS device MP2.  The mirrored current is then dumped into two resistors to generate the output voltage.  These resistors also generate a common-mode output voltage which is used for the common-mode feedback.
The gain is related to the gm of the input device, the two current mirror gains and the value of the output resistor.
Carl
AnalogDE
Reply #4 - Jul 9th, 2010, 4:26pm
What's the function of the branch with MP3?  I don't get that part.
xwj623
Reply #5 - Jul 11th, 2010, 6:23pm
Then what's the role of MP3 & MN5?
It seems that the MP3 and MN5 construct a postive feedback, is there
a stability issue?
Then how the CMFB works?
What the GBW depends on when at a cap loading?
carlgrace wrote on Jul 9th, 2010, 1:46pm:
Carl
XY-oriented
Reply #6 - Jul 12th, 2010, 7:46am
my 2 cents ...the second part of the circuit looks like a 1st generation current conveyor.... though not a conventional one!  ;)
xwj623
Reply #7 - Jul 12th, 2010, 6:37pm
yes, i have ever think about it as a CCI,
but the CMFB circuit seems strange for a CCI.
XY-oriented wrote on Jul 12th, 2010, 7:46am:
