purplewolf wrote on Jul 21st, 2010, 2:15am:Dont mix up the two Q's...
No, you don't understand Q of resonators.
Consider a definition of resonator's Q.Resonator's Q is defined as ratio of reactive energy and loss energy at resonance
for any resonator.
Q of parallel LC-tank resonator is Q=ω
0*L/R, here R means loss of L. This Q is not inductor's Q.
Q of parallel LCR-tank resonator is Q=ω
0*C/G, here G means parallel conductance of LC-tank.
purplewolf wrote on Jul 21st, 2010, 2:15am:wL =wC <=> 1/(ω0*L)=ω0*C <=> 1/(ω0*C)=ω0*L. .. makes no difference.
Again see your description surely.
Do you think "
wL =wC" is surely correct ?
I think your "
wL =wC" makes clear difference compared to 1/(ω
0*L)=ω
0*C <=> 1/(ω
0*C)=ω
0*L.
Your "diffrential.jpg" uses
ideal transfomers which are not physical.
So your "diffrential.jpg" should show lowpass characteristics, since there are no DC-Block capacitors and no resonators.
But actual transfomer is mutual coupled inductors which forms double resonator, that is, coupled LC-tank.
purplewolf wrote on Jul 21st, 2010, 2:15am:I just assume that the bandwidth is either twice (or may be half) incase of diffrential as compared to single ended since it is combination of two single ended..
Again see
http://www.designers-guide.org/Forum/YaBB.pl?num=1278414763/9#9Study characteristics or behaviors of double resonators or coupled resonators
Generally BW will be narrower if you use double resonators.
But if you permit two peak characteristic over passband, you can increase BW using double resonators.
purplewolf wrote on Jul 21st, 2010, 2:15am:I havent found any mathematical proof about its BW in literature..
You seems to be new comer in RF-engineering world.
Such things are decribed in any RF books.
Sorry I don't have international books which are written in English.
Read true classical-RF circuit text books which are oriented for discrete RF circuits not RF-IC's.
Or search old application notes on discrete PA by Motorola(=Currently On-Semi).
