Apr 26th, 2024, 4:30pm
I/O ring Design (Read 8115 times)
NOHA
I/O ring Design
Jul 11th, 2010, 4:36am
Kindly I want to ask about the guidelines that help me to design the I/O ring also I want to know how to connect the the I/O cells with the internal core circuits ?
SATurn
Re: I/O ring Design
Reply #1 - May 18th, 2011, 2:38pm
Generally the best way is to study very carefully the document which comes with the design kit. Most of the time the document includes whatever you need ...
SATurn
SATurn
Re: I/O ring Design
Reply #2 - May 18th, 2011, 2:38pm
SATurn
Re: I/O ring Design
Reply #3 - May 18th, 2011, 6:07pm
designing your own I/O and ESD? Or using foundry provided?
RTFM if foundry provided. Contact foundry support.
harpoon
Hampshire
Re: I/O ring Design
Reply #4 - Jul 26th, 2011, 3:38pm
If you have access to IBM, then they have a whole host of documentation and examples. Also, I have found that their foundry tech support can be quite helpful as well.
That aside, I/O rings are usually concerned about a few things :-
a) ESD protection
b) RF pads (lower parasitic, weaker protection diodes ...)
c) Clamp cells and latchup
d) Analogue to digital stitch up/isolation
e) Power distribution (voltage drops and current handling)
If you cover all of the above, you're in great shape.
