May 20th, 2024, 8:22pm
Hspice MULU0 and DELVTO (Read 6347 times)
aspiceq
UK
Jul 13th, 2010, 1:22am
I have seen MULU0 and DELVTO as mos instance line parameters in (Hspice)  BSIM3 models.
e.g.
m1 d g s b ne l= W= M= MULU0= DELVTO= ...
I understand that they are ways to model device variation on an instance by instance basis MULU0 scales the mobility (of effectively the device width) and DELVTO the threshold voltage shift.
My questions are
1. Are these commonly used by modern PDKs? Or is there a better more standard way to model such variation?
2. Are they intended to model statistical variations of hard shifts in parameter?
With statistical variations one would expect a "random walk" effect when the mos multiplier M is greater than zero - so the impact of the values would be reduced by 1/sqrt(M)?
So in other words, are they in any way modified by the value of M present on the device line? Are simulators consistent in how they handle this?
This gets complicated by implicit passing of M (i.e. M scaling entire subckts).
An example demonstrates my point.
we have something like
DELVTO='5m/sqrt(W*L*1e12)'
but should it not be
DELVTO='5m/sqrt(W*L*1e12*[effective M scaling of subckt and device])'
Dave Gee
(aspiceq)
aLittleKnowledge
Re: Hspice MULU0 and DELVTO
Reply #1 - Jul 13th, 2010, 3:46am
mulu0 and delvtO are intended to model post-layout mismatch from strain etc.  As these effects are sometimes large, some suppliers include MC for these specifically in post layout simulations.
MC for mulu0 and delvtO is handled in the same way as for any other parameter.
aspiceq
UK
Reply #2 - Jul 14th, 2010, 1:38am
Many thanks,
Dave.
