Sep 16th, 2026, 5:52am
What does this mean in ADS --> S[1::2,1::2] (Read 8392 times)
DoYouLinux
Jul 17th, 2010, 8:51am
Hi everyone,
I am trying to study about S parameters in ADS. I have seen from a file that in the "stoy" function, there is a variable defined in Mea Eqn as follows:
Param_y = stoy(S[1::2,1::2]).
In the schematic, there is an element called "S2P" driven by two ports Port 1 and Port 2. I guess that this is to transform S paramters to Y parameters. But, what does the syntax
S[1::2, 1::2] mean ?
Could someone explain to me please ?
Thank you very much,
DYL
Re: What does this mean in ADS --> S[1::2,1::2]
Reply #1 - Jul 18th, 2010, 2:12am
RFICDUDE
Reply #2 - Jul 18th, 2010, 3:02pm
Pancho's link explains what the notation means, but if you want to know a simple way to use the stoy function just use (I think)
stoy(S)
or if you prefer or need z-parameters
stoz(S)
these functions will save the y and z parameter equivalent results for each s-parameter analysis simulation (all ports).
The wildcard and sequence notation would be useful if you are only interested in doing a conversion for some select ports (I think).
I use these functions when I'm interested in calculating the either the series or shunt effective lumped element equivalent resistance, capacitance and/or inductance over frequency.
Reply #3 - Jul 26th, 2010, 3:57am
"[]", "()" and "{}" have completely different meanings each other in Agilent ADS Post Processing Environment.
S parameters are matrix, here you have to use "()" not "[]".
Usually sequence operator, "::" is used for Array not Matrix.
And if we use sequence operators for two-dimensional Array or Matrix, an applied indexing order such as "Row-Major" or "Colum-Major" is ambiguous.
So I confirmed validity of  sequence operator, "::" for two-dimensional Matrix.
It seems an indexing is "Row-Major" as same as C-language.
DoYouLinux
Reply #4 - Jul 26th, 2010, 5:57am
Hi RFDUDE,
Thank you very much for your explanation.
DYL
DoYouLinux
Reply #5 - Jul 26th, 2010, 6:10am
Hi pancho_hideboo,
Thank you very much for your answer. I actually used S(1::2,1::2) in my simulation, not S[1::2,1::2]. I have some further questions regarding your simulation:
1) How did you generate the input S parameters ( S(1,1) = 11+j0, S(1,2) = 12+j0, ...) ?
2) What is the main difference between using S(3::4,3::4) and S{{S33,S34},{S43,S44}} ? I think the result should be the same.
Thank you in advance  :)
DYL
DoYouLinux
Reply #6 - Jul 26th, 2010, 6:23am
Ah, my fault, I mean comparison between S(3::4,3::4) and {{S33,S34},{S43,S44}}, the result should be the same.
DYL
Reply #7 - Jul 26th, 2010, 7:24pm
DoYouLinux wrote on Jul 26th, 2010, 6:10am:
See attached figure.
http://edocs.soco.agilent.com/display/ads2009/S1P+Eqn+to+S6P+Eqn+%281-+to+6-Port...
2) What is the main difference between using S(3::4,3::4) and {{S33,S34},{S43,S44}} ?
Right.
DoYouLinux
Reply #8 - Jul 27th, 2010, 5:29pm
Hi pancho_hideboo,
Thank you very much for your reply. This is my another new knowledge about ADS.
DYL
