DoYouLinux
Hi pancho_hideboo,
Thank you very much for your answer. I actually used S(1::2,1::2) in my simulation, not S[1::2,1::2]. I have some further questions regarding your simulation:
1) How did you generate the input S parameters ( S(1,1) = 11+j0, S(1,2) = 12+j0, ...) ?
2) What is the main difference between using S(3::4,3::4) and S{{S33,S34},{S43,S44}} ? I think the result should be the same.
Thank you in advance :)
DYL
