Jul 17th, 2024, 1:45pm
Coherent and noncoherent receiver (Read 2578 times)
T3N
Jul 19th, 2010, 12:41am
I've just joined this forum a few days ago and I am a newbie in RF design. Hope that I can learn a lot from you guys. Currently, I am reading on system design topics. The book I am reading is RF microelectronics by Razavi. Based on what I learn, there are basically three types of receiver: zero-IF, low-If and heterodyne. In Razavi’s book – “Digital modulation” chapter, he classifies the receiver in to two types: coherent and non-cohenrent. Detection schemes that require phase synchronization are called “coherent”.
So this is my question. If a zero-IF or low-IF has I and Q path, does it require a phase synchronization to avoid the start-up phase uncertainty of the oscillator? And in the case it requires a phase synchronization, will it be classified as a coherent receiver as well?
Thank you.
T3N
Re: Coherent and noncoherent receiver
Reply #1 - Jul 24th, 2010, 11:39pm
T3N wrote on Jul 19th, 2010, 12:41am:
No.
Yes.
Whether it is Coherent-scheme or Noncoherent-scheme is a matter of signal detection.
It is no relation to frequency conversion scheme such as  zero-IF, low-If and heterodyne.
Note : low-IF is no more than heterodyne and zero-IF is homodyne.
But sometimes there is a case where homodyne means zero-IF with coherent detection.
« Last Edit: Jul 25th, 2010, 3:17am by pancho_hideboo »
vp1953
Reply #2 - Jul 26th, 2010, 9:58am
HI T3N,
>So this is my question. If a zero-IF or low-IF has I and Q path, does it >require a phase synchronization to avoid the start-up phase uncertainty
What is the modulation scheme you are using? It really depends on that. FSK, ASK dont need phase synchronization. Even though ASK does not need phase synchronization, you still need I and Q paths - since depending on the distance from the transmitter, the entire received signal can be in the I channel or the Q channel (so having only one channel can result in missed signals). Even with I and Q, this does not classify as a coherent reeiver. FSK with a direct conversion architecture does not need I and Q; a low IF FSK receiver may use I and Q (for image rejection etc) but still does not classify as a coherent receiver.
