Sep 15th, 2026, 4:08pm
type check error, problem with terminal (Read 972 times)
chippendale
Jul 23rd, 2010, 4:57am
Hi there,
I have an terminal bus.
terminal test:electrical_vector(0 to3);
I assign a constant through quantity to these terminals.
test(0 to 3) == -10.0e-6;
The output message of the compiler is
"type check error: expression is not a type IEEE.ELCTRICAL_SYSTEM.__THROUGH_ELECTRICAL_VECTOR"
and references to the above given text passage
Any ideas?!
chippendale
Re: type check error, problem with terminal
Reply #1 - Jul 23rd, 2010, 5:59am
I found the solution. The assignment has to look like this
test(0 to 3) == (others => -10.0e-6);
