Sep 17th, 2024, 5:16am
PLL-based CDR and PI-based CDR (Read 11999 times)
neoflash
Mixed-Signal
Designer
Jul 26th, 2010, 9:06pm
PLL-based CDR seems to be the main stream in the early days of data com. Recent ten years the PI-based design has appeared to dominate over.
What's the cons and pros of the two different architectures?
Neo
supermoment
Re: PLL-based CDR and PI-based CDR
Reply #1 - Jul 27th, 2010, 12:23am
PI based designs have two types. One is analog PI and the other one is digital PI. digital PI is favorable and popular since it is robust and no analog filter!! the drawback is the finite resolution.
love_analog
Reply #2 - Jul 29th, 2010, 7:08am
Good question..
With PLL based ones, you need to have a PLL for each CDR.
For multi-lane I/O applications and scalability, this is expensive.
people have a central PLL, clock distribution to the I/O lanes and put a PI in each lane to generate the sampling clock.
loveanalog.blogspot.com
The Power of Analog
colossus_bade
Reply #3 - Sep 19th, 2010, 12:00am
PI-based CDR will generate multi-step phase jumps when input data & local PLL have frequency offset, and will degrade jitter torlerance. If there is different SSC@input data & local PLL, this could be worse. Maybe this is the main weakpoint of PI-baseed CDR. Or there are already some cure for this problem, plz let me know, thanks very much Smiley
love_analog
Reply #4 - Oct 11th, 2010, 6:33am
Typical PI based CDR have a 2nd order loop. The integrating loop will handle the frequency difference.
So Jitter tolerance is not degraded
The Power of Analog
SATurn
Reply #5 - May 18th, 2011, 2:33pm
Just a short addition: PLL-based CDR provides the possibility of recovering the frequency while it is limited in the PI-based CDRs.
SATurn
BackerShu
Reply #6 - Oct 15th, 2011, 12:29pm
To my certain knowledge,
PLL-based CDR usually encounters a tradeoff between the Jitter Transfer and Jitter Tolerance since their cut frequencies are dependent to each other.
Multichannel Crosstalking, as mentioned above, is also a annoying problem in PLL-based CDR.
PI-based CDR usually is limited by its phase jump, or quantization noise, and multiphase clock routing could also be a problem.
I think both of them could provide clock and data recovery.
Reply #7 - Oct 23rd, 2011, 7:47pm
If you already have a common clock using PI is smaller and  generally consumes less power.
if you don;t have frequency locked signal avaialble then you need the PLL.
