Jul 17th, 2024, 11:25pm
Problem in finding slew rate (Read 3372 times)
kanu
Jul 29th, 2010, 6:04am
I tried finding slew rate of a 2-stage opamp.. but for some reasons the output waveform gives oscillations. I thought I would have switched the input terminals.. but that looks good. Bias circuit is fine too. It gives the constant voltage of 0.4 V to bias NMOS. What else could be a possible reason for such behavior?
I will appreciate any help.
Kanu
kanu
Re: Problem in finding slew rate
Reply #1 - Jul 29th, 2010, 8:41am
Hi All,
One more question.. How does one find slew rate of an uncompensated opamp?
Kanu
raja.cedt
Reply #2 - Aug 2nd, 2010, 10:20am
hi kanu,
method of finding slew rate for any class of an op with any method of compensation is same..because even if you don't have any compensation may be some parasitic cap will charge with ramp profile. Simulate and let me know i am sure you don't get into any problem.
HdrChopper
Reply #3 - Aug 4th, 2010, 4:48am
Are you testing the opamp in closed loop or open loop form?
You should try it in open loop, without any feedback network connected and simply switch the inputs with a large overdrive.
The ouput should switch from rail to rail with a certain slew rate.
Best
Tosei
Keep it simple
kanu
Reply #4 - Aug 5th, 2010, 11:18am
Hi Tosei,
Thanks for your reply. I asked above question about uncompensated opamp, as I wanted to confirm if I measure transient response of opamp for pulse in open loop configuration.. will this be enough to determine its slew rate ? If so, then I don't need to worry. Otherwise first I will have to make my opamp stable for unity gain configuration Sad
I think from your post, you do mean that transient response is enough. Do let me know if you think I have interpreted it wrong.
Kanu
HdrChopper
Reply #5 - Aug 5th, 2010, 5:54pm
Hi Kanu,
Yes, the transient response should be enough since slew rate is a large signal parameter and as such the best way to predict it is by transient analysis.
Best
Tosei
Keep it simple
