Hi Tosei,
Thanks for your reply. I asked above question about uncompensated opamp, as I wanted to confirm if I measure transient response of opamp for pulse in open loop configuration.. will this be enough to determine its slew rate ? If so, then I don't need to worry. Otherwise first I will have to make my opamp stable for unity gain configuration
I think from your post, you do mean that transient response is enough. Do let me know if you think I have interpreted it wrong.
Kanu
