Sep 18th, 2026, 10:03am
dfferent freq results in pss vs transient (Read 12381 times)
supermoment
Aug 07th, 2010, 12:40am
in the QLCVCO (cmos type with bottom bias), freq vs vctrl (vc) are plotted using pss and transient methods.
At the vc=0.8V, transient result has a dip to much lower frequency, however the pss results looks ok. In the instantaneous freq plot (transient sim), it confirms that the vco has settled down.
However, which result is reliable? At the end, i got to simulate whole pll in transient mode.
Re: different freq results in pss vs transient
Reply #1 - Aug 7th, 2010, 1:32am
I can't find out any design issue in your post.
supermoment wrote on Aug 7th, 2010, 12:40am:
Show me time domain waveforms at vc=0.8V both for PSS and Transient Analysis.
Result of PSS is reliable.
Tighten accuracy of Transient Analysis, e.g. "reltol".
See http://www.designers-guide.org/Forum/YaBB.pl?num=1237627988/5#5
« Last Edit: Aug 7th, 2010, 10:44am by pancho_hideboo »
supermoment
Re: dfferent freq results in pss vs transient
Reply #2 - Aug 7th, 2010, 3:04am
i have tried 2 methods to confirm that PSS run is more accurate
1) change reltol from 1e-3 to 1-5
2) sim conservative run
the diagram shows the conservative run overlapping with pss result.
thx
Reply #3 - Aug 7th, 2010, 3:08am
supermoment wrote on Aug 7th, 2010, 3:04am:
I think you can understand you have to pay attention to accuracy of Transient Analysis of Cadence Spectre if you use it for VCO analysis.
Most serious issue is such irregular large deviation from correct value.
I often encounter irregular large deviation from correct value when I use Cadence Spectre.
You could not notice such large deviation, if you simulate only one point such as vc=0.8V.
Even if I use Golden Standard HSPICE, I can observe deviation from correct value if I don't tighten accuracy such as "delmax".
But I never encounter such extraordinal deviation when I use Golden Standard HSPICE.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1237627988/5#5
I always set "maxstep" for VCO analysis if I use Cadence Spectre.
« Last Edit: Aug 7th, 2010, 10:43am by pancho_hideboo »
Reply #4 - Aug 7th, 2010, 7:24pm
Casual,
  Can you explain more about your measurement methodology?
1) How long do you allow for the VCO to settle to steady-state?
2) How do you measure period?
   Do you measure for one period to calculate the frequency?
   Do you average over several periods to calculate the frequency?
   Do you use the frequency meter?
   The results for both tools should be consistent. However, it is more
difficult to perform the measurement using transient analysis.
vp1953
Reply #5 - Aug 8th, 2010, 9:35am
Hi Sheldon,
Why would be period be different with and without averaging for transient analysis (assuming that noise sources are not enabled)?
vp1953
Reply #6 - Aug 8th, 2010, 10:57am
Hi Sheldon,
Come to think of it, the presence of higher tones in the spectrum can create a difference between a single period and averaged period - is this what you had in mind?
supermoment
Reply #7 - Aug 9th, 2010, 7:59pm
Seldon,
The first method I use is to measure frequency of the clk after a long settling time about 30ns in the transient analysis since I still new in PSS. You could see from the instantaneous freq waveform that it has settle down to around 4.88GHz. So one freq and average freq will be almost the same (small variation).
I do not know what the freq meter about? is it written in verilogA?
from the study here, found that sweep PSS is the best method to extract vco gain behaviour.
However, in the close loop simulation, it is still running in transient mode. So it is great to check in transient mode (my point of view) and adjust the accuracy setting.
Reply #8 - Aug 10th, 2010, 5:22pm
Casual,
  With adaptive time stepping, the simulator will not necessarily stop at
the instance in time required for the frequency measurement and as a
result, there will be interpolation error. By averaging the effect of
interpolation error is reduced.
   The freq_meter is an element that was created for the noise aware
PLL flow and is in the pllMMLib, (requires Spectre RF license). The
component is used to measure the frequency at the output of a VCO
or PLL in the time domain. It also enables time domain measurement
of phase noise, Direct Plot --> main form --> tran --> PLL Noise PSD.
supermoment
Reply #9 - Aug 10th, 2010, 8:56pm
sadly, i do not have noise aware pllflow for mmsim61 ic5.1.41
Could i do this in manual way with the calculator?
Reply #10 - Aug 11th, 2010, 4:05am
Casual,
  No, this functionality is not supported in the calculator. I suspect that
the approach is similar to the approach described in Ken's paper on
PLL modeling and simulation.
    http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
Reply #11 - Aug 11th, 2010, 6:51am
You could use a verilog-a module to accurately measure the frequency. You can probably use the one on this site (http://www.designers-guide.org/VerilogAMS/functional-blocks/periods.tgz). You can plot the internal variable 'freq' to show frequency versus time.
supermoment
Reply #12 - Aug 12th, 2010, 12:41am
thank you very much.
