Jul 17th, 2024, 3:25pm
RF Differential input Single-ended Output Amplifier (Read 6341 times)
mohammadreza
Aug 09th, 2010, 3:36am
I am designing an RF PA which is almost ready. I used a VCVS to convert my differential input signal. But now, I am supposed to make an RF Amplifier as well, which doesn't necessarily amplify very much, but can convert my differential input signal to a single-ended one. What I am looking for is an inductorless type. My operating frequency is 2.4GHz, so the traditional lower frequency OpAmps don't help.
Please let me know if any idea poped into you.
RFICDUDE
Re: RF Differential input Single-ended Output Amplifier
Reply #1 - Aug 10th, 2010, 5:44pm
Yes, lots of ideas popped into my head.
Smiley
mohammadreza
Reply #2 - Aug 14th, 2010, 4:45am
so...?
Smiley Cool
Reply #3 - Aug 14th, 2010, 9:55pm
Perhaps you should asked a specific question.
mohammadreza
Reply #4 - Aug 16th, 2010, 1:49am
Actually, the what i knew was using an Op-Ampl and trying to seprate it's poles and getting small gain out of it at the intended frequency. that's practical for under 1GHz as the TI suggests but not for the 2.45GHz.
Another method is using charge pumps, but that's not helpful in ultra low power (-10dBm).
almost all I found in searching the databases is about differential low noise amplifiers whcih are either single-ended input and differential output or they are totally differential.
So, have you got any idea or any document that can link it here?
carlgrace
Berkeley, CA
Reply #5 - Aug 17th, 2010, 6:40pm
You could try an NMOS diff pair and then just take the output from one drain.  This would be very fast, but you would lose half of your gain.  What linearity do you need?   You said you used an op amp, but I think you will need an open-loop amplifier.
mohammadreza
Reply #6 - Aug 18th, 2010, 2:13am
yes, you are right, but the fact is utelizing a differential pair and even mirroring the output consumes lots of current and the poles that are created make the amplifier have a gain far below 0dB, in 2.4GHz.
But if there is a way to increase the gain and seperate the poles to very high distance and get even unity gain, that would be helpful.
But, maybe it is easier to kill one side of the input and just amplify one.
mohammadreza
Reply #7 - Aug 18th, 2010, 2:14am
by the way, linearity is not an issue for me. using linear class is because in the ultra low power using switches requires amplifying the signal to rail to rail which consumes more power.
rfcooltools.com
Reply #8 - Aug 18th, 2010, 9:54am
Diff pair to a resistor load that is differential.  Then to convert to single ended try using a  "totem pole circuit",  you can look them up on the internet for a schematic. or you can connect to one of the resistors as suggested by carlgrace  and use  "white's cascode" to buffer this output.
http://rfcooltools.com
