purplewolf wrote on Aug 10th, 2010, 6:44am:1) The PAE does not depend on the input matching network , its only the power gain that depends on it. The PAE of a input mismatched PA will be same as the matched one..
Wrong.
purplewolf wrote on Aug 10th, 2010, 6:44am:2)The input matching s parameters depends on the Ropt --> 50 ohms transformation network and is independent of the harmonic supression network on the output of the device..Since Ropt -->50ohms network is tuned at fo ..
I can't understand what you want to mean.
However I think you are misunderstanding.
Γ
in and Γ
out are not independent each other since S
12 is not zero.
Also input wave shape is affected by input matching largely and then it affects PAE.
