Quote:Whether you do 8b/10b or 64b/66b, this only dictates max run lenght and not the transition densisty
Defining max. no. of #1s or #0s in a particular bit stream also defines the min. transition density that can be encountered in a certain time window.
Every encoding specifies with itself a min. transition density that it will maintain.
@ casual: I think its 0.3 for 8b/10b encoding. Pls. confirm.
Mayank.
