May 12th, 2024, 1:52am
CDR transfer function & BW (Read 7044 times)
supermoment
Aug 15th, 2010, 6:48pm
When we measure CDR transfer function, what is the input data pattern to the CDR? Is it a random data or 10101 data?
CDR BW for oc192 SONET is at least 4MHz for jitter tolerance requirement. Loop BW formula is alpha*K_total*R where alpha is data density.
If i use 101010 data pattern, the BW is K_total*R since alpha =1
If i use random data pattern, the BW is 0.5*K_total*R because alpha =0.5.
It gives me two set of BW.
supermoment
Re: CDR transfer function & BW
Reply #1 - Aug 16th, 2010, 10:41pm
random data is used in transfer function measurement. So i think alpha=0.5 should be used.
Mayank
Reply #2 - Sep 7th, 2010, 9:09pm
For actual results, use the transition density of the data stream which you are recovering. Transition density of incoming data stream differs for different protocols & is chiefly dependent on the type of coding used. [ 8b/10b OR 64b/66b ] In some cases, it can go as low as 0.2
--Mayank.
supermoment
Reply #3 - Sep 23rd, 2010, 3:07am
I am referring to PRBS input without any coding. It can test the robustness of the receiver circuit like long consecutive 1 or 0.
( line coding like 8B10B is for system level test).
So the data density is 0.5 for PRBS data input.
I think the 8B10B also has data density 0.5
64B/66B has much lower data density since it depends on data scrambler and data.
Am i correct?
love_analog
Reply #4 - Oct 11th, 2010, 6:38am
Data dentisity refers to #1s or #0s over the total number of bits.
Whether you do 8b/10b or 64b/66b, this only dictates max run lenght and not the transition densisty
As long as you have scrambled/PRBS data, you will get .5
loveanalog.blogspot.com
The Power of Analog
Mayank
Reply #5 - Oct 22nd, 2010, 2:02am
Defining max. no. of #1s or #0s in a particular bit stream also defines the min. transition density that can be encountered in a certain time window.
Every encoding specifies with itself a min. transition density that it will maintain.
@ casual: I think its 0.3 for 8b/10b encoding. Pls. confirm.
Mayank.
