Jul 17th, 2024, 11:38pm
higher charge pump current yields lower PD noise (Read 4444 times)
supermoment
Aug 16th, 2010, 1:46am
"In general, a higher charge pump current yields lower phase detector noise."
What is the reason behind?
Is it because the R got to be reduced for large charge pump current in a given loop bandwidth?
raja.cedt
Re: higher charge pump current yields lower PD noise
Reply #1 - Aug 16th, 2010, 3:57am
hi,
   is your question correct. I think it should be like Higher current implies lower Noise contribution from charge pump., because  transfer function from charge pump to PLL out is inversely proportional to charge pump current.
Rajasekhar.
supermoment
Reply #2 - Aug 16th, 2010, 4:29am
it is quoted from Prof Micheal Perrott (MIT) document...
still figuring out..
raja.cedt
Reply #3 - Aug 16th, 2010, 5:30am
hi,
could you please share that doc..?
Rajasekhar.
vp1953
Reply #4 - Aug 16th, 2010, 11:23am
Higher charge pump current results in higher loop gain and larger loop bandwidth if the loop filter components are not changed. Larger loop bandwidth leads to greater suppression of close in phase noise.
supermoment
Reply #5 - Aug 16th, 2010, 10:38pm
see attachment
