Jul 17th, 2024, 3:34pm
Placement of the SAW filter (Read 159 times)
vp1953
Aug 17th, 2010, 4:58pm
Hi All,
Typically for ASK/FSK transceiver chips, we find that the saw filter is placed at the receiver; the other end of the SAW filter goes to the R/T switch which is connected to the antenna.
Is there any issue that prevents the SAW filter from being placed  between the R/T switch and the antenna (instead of at the receiver)?
Re: Placement of the SAW filter
Reply #1 - Aug 18th, 2010, 10:25am
vp1953 wrote on Aug 17th, 2010, 4:58pm:
Load stability of TX-PA.
Consider impedance of SAW especially for stop band.
vp1953
Reply #2 - Aug 18th, 2010, 12:00pm
Hi P_H,
Thanks for the excellent suggestion. Is there any way this can be simulated?
rfcooltools.com
Reply #3 - Aug 18th, 2010, 3:45pm
Adding to pancho_hideboo's comments
The saw will not see any loss between it and the antenna therefore the return loss will vary by two times the insertion loss of the switch.   You could say that the impedance seen looking into the antenna from the saw filter will vary more.
Also
Tx path will now have a saw as loss so output power will be reduced by the saw insertion loss
The benefits is that fcc spurious transmission requirements will be easier to be met.
do you have an s2p file of the saw filter and switch if so check out my simulator where you can load them in and quickly try some what if scenarios for matching return loss etc.
http://rfcooltools.com
vp1953
Reply #4 - Aug 19th, 2010, 10:35am
Hi RFcooltools,
Thanks very much for your input. I will definitely play around with your simulation tool - looks pretty interesting!
rfcooltools.com
Reply #5 - Aug 20th, 2010, 10:07am
Thanks vp1953,
Feel free to let me know what you think good or bad!
