May 13th, 2024, 12:37am
Correlation of S-D Synthesizer in time domain and freq domain (Read 3117 times)
neoflash
Mixed-Signal
Designer
Aug 22nd, 2010, 11:48am
Hi guys,
I'm doing a simulation of a 3rd order SD based synthesizer in time domain and its analysis in frequency domain.
Also, I'm using Perrot's PLL assistant software for reference.
The result is not that close between time domain and frequency domain. I will attach them both in the post. I'm using hspice + verilogA for time domain simulation. (Perrot's software for some reason give the same result for 3rd order and 2nd order modulator so the result from his cppsim is not used here. )
I've tried a couple of ways to correlate them but still not close enough. Not sure which result is correct.
The parameter I used:
Kvco = 1e9 Hz/v
Fref  = 156.25e6
Rz    = 5k
CB   = 1n
Cs    = 8pf
N     = 19.125337
Modulator order = 3
Thanks for advice.
(As shown in the figure, time domain shows much higher noise than frequeny domain)
neoflash
Mixed-Signal
Designer
Re: Correlation of S-D Synthesizer in time domain and freq domain
Reply #1 - Aug 22nd, 2010, 12:39pm
2nd order modulator case is a little better. But still some difference.
vp1953
Reply #2 - Aug 23rd, 2010, 4:57pm
Hi Neo,
- can you detail how you did the frequency domain simulation?
- in your time domain model, was the VCO the only noise source and were all blocks in VerilogA?
- for the time domain again, for how many cycles (I am guessing fc is around 3GHz) was it run and how did you calculate the phase noise plot?
vp1953
Reply #3 - Aug 23rd, 2010, 4:59pm
For the second plot, a little away from the y-axis the difference between the time domain and frequency domain waveforms is almost consistently 6dB. Seems like a divide by 2 is missing in the calculations..
vp1953
Reply #4 - Aug 23rd, 2010, 8:30pm
Why would the small signal ac analysis be close to time domain simulation results? Even for simple baseband signals, there can be considerable difference.
I'll bet that some of the individual blocks (not the VCO) can have differences of several db between small signal analysis and time domain analysis. If you do find out that there is this difference in their transfer functions, please do let me know - I am curious about it.
