liletian
MD
Hi Guys I am thinking to use advanced circuit (4pcb.com) service to make tranmission line (MLIN 50 Ohms). However, I can not find info on each layers. If anyone can give me a link or supply info on thickness of each layer, it will be greatly appreciated. I found the following info on the website. 4-Layer PCB - 0.062" finished thickness
Layer 1 - Copper - 0.0014" thick (1 oz. copper weight) Laminate (prepreg) - 0.0115"-0.0129" thick - Dielectric Constant of 4.6 Layer 2 - Copper - 0.0014" thick (1 oz. copper weight) Core material - 0.028" thick - Dielectric Constant of 4.7 Layer 3 - Copper - 0.0014" thick (1 oz. copper weight) Laminate (prepreg) - 0.0115"-0.0129" thick - Dielectric Constant of 4.6 Layer 4 - Copper - 0.0014" thick (1 oz. copper weight)
Please comments how accurate it is. I added all the layer's thickness together and found it is less than 0.06 inch. thanks
