Aug 16th, 2024, 7:49pm
what is the thickness of each layers of 4 layer 0.062 inch? (Read 2092 times)
liletian
MD
Aug 22nd, 2010, 6:10pm
 Hi Guys
 I am thinking to use advanced circuit (4pcb.com) service to make tranmission line (MLIN 50 Ohms). However, I can not find info on each layers. If anyone can give me a link or supply info on thickness of each layer, it will be greatly appreciated.
I found the following info on the website.
4-Layer PCB - 0.062" finished thickness
Layer 1 - Copper - 0.0014" thick (1 oz. copper weight)
Laminate (prepreg) - 0.0115"-0.0129" thick - Dielectric Constant of 4.6
Layer 2 - Copper - 0.0014" thick (1 oz. copper weight)
Core material - 0.028" thick - Dielectric Constant of 4.7
Layer 3 - Copper - 0.0014" thick (1 oz. copper weight)
Layer 4 - Copper - 0.0014" thick (1 oz. copper weight)
Please comments how accurate it is. I added all the layer's thickness together and found it is less than 0.06 inch.
thanks
Re: what is the thickness of each layers of 4 layer 0.062 inch?
Reply #1 - Aug 31st, 2010, 10:42am
contact the manufacturer.....
rfcooltools.com
Reply #2 - Sep 1st, 2010, 1:22pm
liletian,
Around 50 to 60 mils is pretty common for a four layer pcb,
Remember that the inner copper layers don't add total height since the prepreg fills the space around the conductor.
http://rfcooltools.com
