Apr 28th, 2024, 3:38am
A problem encountered in AMS simulation (Read 3419 times)
chip
Sep 06th, 2010, 1:59am
I simulate my analog circuit with verilog code for digital using AMS simulator in ADE, it displays the error message when elaborating as following:
Digital or mixed-bus connections(with digital) not supported at Spice boundry.
I can not find any useful information about that on the internet,Does anyone know the reason? Thanks a alot. Huh
Re: A problem encountered in AMS simulation
Reply #1 - Sep 13th, 2010, 8:17am
Did you setup any connect rule? What's the analog simulator?
Yawei
AMS_ei
Reply #2 - Apr 19th, 2017, 10:08am
I am looking at this post now. I am not sure if this problem has been resolved from your end. However, I have a suggestion for you.
Create an amsd block in an .scs file ( say amscf.scs) and there use portmap subckt=<subckt_name> porttype=name as shown below:
amsd {
            config cell=<cell_name_generally_module_name> use=spice
This will generate a portbind file which will have all the spice and verilog port mapping.
Hope this helps.
Thank you.
