Aug 4th, 2024, 5:22am
Pages: 1 2
Big Contributor of Phase Noise in Hysteresis Buffer (Read 10943 times)
vp1953
Re: Big Contributor of Phase Noise in Hysteresis Buffer
Reply #15 - Sep 20th, 2010, 6:36pm
Hi Pancho
Quote:
Contribution of fricker noise to sideband noise could be larger for sharp transition since conversion gain is larger.
After thinking about this a little bit, I completely agree with you - this could be the reason. Basically stationary noise sources get convolved with response of the circuit to give your usb noise behaviour.
If flicker noise comes down with with increasing W, and USB noise increases with W, then the spectral components (fourier components, not PSD) at the output of your hysteretic invertor must increase by factor between  varying between W^1/2 and W (a first order calculation). Is this the case for your circuit?
Lex
Eindhoven, Holland
Reply #16 - Sep 22nd, 2010, 4:11am
I fear that the results of the upconversion of 1/f noise of the switches are not that accurate.
Did you checked the papers from Klumperink on this specific topic?
Reply #17 - Sep 22nd, 2010, 6:34am
Lex wrote on Sep 22nd, 2010, 4:11am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1285083976
Fricker noise contribution is treated as upconversion from DC in any slave small noise analysis subjected to master large signal steady state analysis.
What are you fearing.
Indeed we can never evaluate sideband noise of very small offset frequency from carrier accurately even if we use any commercial simulator.
http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/20#20
http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/26#26
http://www.designers-guide.org/Forum/YaBB.pl?num=1263835149/6#6
http://www.designers-guide.org/Forum/YaBB.pl?num=1260521995/5#5
« Last Edit: Sep 22nd, 2010, 12:11pm by pancho_hideboo »
Pages: 1 2
