Aug 4th, 2024, 7:24am
switched-capacitor circuit need your help (Read 3336 times)
lhlbluesky_lhl
Sep 16th, 2010, 5:52am
i have designed a sc circuit, as the figure shows, Cs=Cf, Vout=Vout+ - Vout- = (Vin+ - Vin-) - (Vref+ - Vref-), Vin = Vin+ - Vin- = (0V~2V), Vref = Vref+ - Vref- = 1V, Vout = Vout+ - Vout- = (-1V~+1V), my question is, when the output is small (150mV or small), the settling accuracy decreases a lot, for example: when (Vin+ - Vin-) - (Vref+ - Vref-) = 1.2V, the settling accuracy is 14bit (Vout = 1.19994V), but when (Vin+ - Vin-) - (Vref+ - Vref-) = 100mV, Vout = 99.85mV (9 bit accuracy), when (Vin+ - Vin-) - (Vref+ - Vref-) is even smaller, the settling accuracy is 8bit or less, why? what is the possible reason?
Cs=1.3pF, opamp is two stage (fold cascode + common source) with cascode compensation.
please help me, thanks all.
RobG
Bozeman, MT
Re: switched-capacitor circuit need your help
Reply #1 - Sep 16th, 2010, 7:48am
First of all, how much error are you expecting due to finite opamp gain?
Part of the error is probably signal independent. In other words, an offset. If you were to check it with zero input you'd have an error but that doesn't mean it is only good to zero bits.
Your errors are 60uV and 150uV respectively and it is pretty easy to get that much offset from charge injection or simulation errors.
rg
carlgrace
Berkeley, CA
Reply #2 - Sep 16th, 2010, 2:32pm
I think your amplifier is probably doing OK.  The accuracy is defined in terms of LSBs, not absolute voltages.  Otherwise, you would expect you amplifier to be getting more accurate at smaller inputs.
Here is a thought experiment to explain what I mean.  Imagine you wanted your amplifier to settle to 10b (about 1 part in 1000).  Your full-scale is 1V.  So if you put in a volt, and have unity gain, you would expect an output of 999mV, for a 1mV settling error (1 LSB at a 10-bit level).  Now put in 10mV.  For 1-part-in-1000 settling you now expect only an error of 10 uV!  Your settling in that case would probably be upset by thermal noise (I don't know the performance of your op amp)
Carl
lhlbluesky_lhl
Reply #3 - Sep 17th, 2010, 7:58am
the opamp performace is good, GBW and PM , DC gain are all OK.
as the above says, accuracy is related to LSB, that is, for full scale of
2V, 1LSB=0.5mV for 12 bit accuracy, when the input is 100mV, and
the output is 99.8mV, it is also 13bit accuracy, am i right?
in another word, my simulation result above (100mV - 99.85mV) is
OK for 12 bit accuracy, am i right?
please correct me if i'm wrong, thanks all.
HdrChopper
Reply #4 - Sep 19th, 2010, 6:54pm
I think it is natural for every circuit (not only yours) to have smaller accuracy as the signal level decreases, and the reason is simple:
since the noise (or error) source remains constant the signal level varies. Thus the signal to noise ratio diminishes and therefore the equivalent number of bits gets reduced; where ENOB is calculated as the log2(SNR)
Best
Tosei
Keep it simple
lhlbluesky_lhl
Reply #5 - Sep 20th, 2010, 5:14am
thanks all, any other ideas?
